Riveted the F-01206A-1 to the F-01222-L-1 & -R-1 and to the F-01223-L-1 & -R-1 using LP4-3 rivets per figure 2 reference page. Riveted F-1206G-L & -R to the F-01206A-1 and the F-01221-L-1 & -R-1 using LP4-3.
Dimpled #30 and #40 the holes in the top flange of the F-01206H-L-1 & -R-1 ribs that correspond to the dimpled holes in the F-01224-L-1 & -R-1 Floors.
Riveted the F-01206H-L-1 & -R-1 ribs to the F-01206A-1 using LP4-3 rivets. Rivited the ELT Bracket Assembly to the F-01206A-1. Riveted F-01224-L-1 & -R-1 to the F-01206A-1 and the F-01206H-L-1 & -R-1 using LP4-3 and CS4-4 Rivets per figure 3 reference page.
Riveted 10 K1000-08D nutplates using AN426AD3-3.5 and CCR264SS-3-2 rivets per figure 3 same page.
Trimmed off the top 1/4 inch portion of the F-1206J angle and separated into -L and -R parts per figure 4 reference page.
Dimpled #40 one set of nutpate attach holes in the F-01206F-2 and one K1000-3 nutplate. Riveted F-01206F-2 to the F-1206J-L & -R using 6 AN470AD4-4 rivets. Riveted the F-1206F-2 to the F-01206A-1 with the rivets coming from the aft side of the F-01206A-1 using LP4-3 rivets.
Separated F-1250 into -L & -R parts per figure 2 21iS/U-05 filed and deburred. Then Riveted the F-1250-L & -R to the F-1220A and F-1220B using LP4-3 rivets per figure 3 same page creating the Pulley Bracket Assembly.
