Cleco'ed then riveted the Inbd Nose Rib & Bracket Assembly, A-1210-R Inbd Nose Rib, the remaining 2 A-1205 Main Ribs, and the A-909/A-1204-L &-R Outbd Nose Rib/Counterbalance Assembly to the A-1203 Spar per figure 1 same page.
Cleco'ed the A-1202B Outbd Flaperon Skin and A-1202A-R Inbd Flaperon Skin to the A-1205 Main Ribs and A-1203 Spar. Checked the skins to ensure they were sitting properly per figure 2 page 18-06. Riveted the Outbd flaperon skin and inbd flaperon skin to the A-1205 Main Ribs and to each other per figure 1 same page.
Cleco'ed the A-1201C-R Outbd nose Skin to the under structure as shown in figure 1 same page. Riveted the outbd nose skin to the under structure Except along its inboard edge where the A-1201B-L Mid Nose Skin overlaps per figure 1 page 18-06.
Cleco'ed the A-1201A-R Inbd to the under structure as shown in figure 1 same page. Match drilled #30 the holes common between the inbd nose skin and the A-1210-L & -R, inserting cleco's after each hole. Removed the #40 cleco's and final drilled #30 those holes.
Removed the A-1201A-R Inbd Nose Skin and deburred all the holes.
Cleco'ed the A-1201A-R Inbd Nose Skin and the A-1201B-R Mid Nose Skin to the under structure as shown in figure 1 same page and then riveted the inbd and mid nose skins to the under structure using LP4-3 rivets.
Applied a thin film of Loctite 243 blue to the first third of the threads of 2 MD3614M Rod End Bearings and screwed them into the ends of the A-1206's and allowed to dry for 24 plus hours.
