Brief Description: Attached and tested Left Nav/Pos/Strobe
Crimped female Molex pins on the ends of all the wires coming from the LN-200-1 Wing Tip Nav/Position/Strobe Light and Snapped the female pins into a male Molex connector housing per schematic page 40iS/U-05. BLK to Pin 1, YEL to Pin 2, GRN to Pin 3, and RED to Pin 4.
Connected the Molex connector housings together for the LN-200-1, secured with a tie wrap, and pushed all the wires and connectors back into the wing tip through the access hole in the W-1222-L and slid the light onto the mount bracket and secured it in place with the set screw at the aft edge per figure 3 page 40iS/U-10.
Attached a 14V battery to the wing root connector and tested the landing light and the nav/position/strobe light.
