306TD Web Site
Date:  1-31-2021
Number of Hours:  5.00
Manual Reference:  40iS/U-08
Brief Description:  Attach Fiberglass Extension for Left nav/position/
Drilled #30 the top center two holes into the W-1222-L and W-1204-E-L. Removed the W-1222-L and sanded away excess flox. Removed and discarded modeling clay used in previous step.
Using the dimples molded in the flat face of the W-1222-L, aligned the LN-200-1 wing tip nav/position/strobe light mount bracket and clamped it in place with a spring clamp.
Match drilled #27 the holes in the mount bracket into the W-1222-L per figure 1 page 40iS/U-09.
Marked 1 inch forward from the center of the two forward holes just drilled and drilled #30 a pilot hole. Then used a step drill to enlarge the access hole to 1 inch per same figure.
Machine Countersunk 120 degrees all the attach holes in the upper flange of the W-1222-L for the head of a CS4 rivet as per same figure.
Finish sanded the edges of the W-1222-L.
Attached the LN-200-1 mount bracket to the W-1222-L using 3 AN365-632A nuts and 2 AN507-6R6 screws and 1 AN507-6R8 screw. Per figure 1 same page attached the ring terminal of the B6309 (BLK) to the inside of the W-1222-L on the AN507-6R8 screw.
Cleco'ed the W-1222-L back to the wing tip and masked the edge and perimeter with electrical tape per figure 1 page 40iS/U-10.
Removed the W-1222-L from the wing, added a thin layer of fuel tank sealant to the inside surface of the lower flange, pulled the female Molex connector housing through the access hole then cleco'ed and riveted the W-1222-L to the wing using 6 CS4-4 flush head rivets on the upper flange and LP4-3 rives on the lower flange. Used a radiused popsicle stick to fillet the fuel tank sealant and removed the tape and left to dry overnight.
