306TD Web Site
Date: 1-23-2021
Number of Hours: 8.00
Manual Reference: 40iS/U-06
Brief Description: Finishing Left Landing Light
Riveted the W-1223B-L & -R to the W-1203-R-1 per figure 1 page 40iS/U-06.
Routed the L6310 (WHT) Nav/Position/Strobe cable outboard through the snap bushingss in the W-1223B-L and -R and through the snap bushing in the most outboard W-1208 Nose Rib to the wing tip per figure 1 same page.
Routed the L213 (YEL), L214 (RED), and L7514 (BLU) through the snap bushing in the inboard W-1223B only per figure 1 same page.
Snapped the female Molex sockets on the L213 (pin 3), L214 (pin 4), and L7514 (pin 2) into the mail Molex connector housing on the end of the L215 (BLK) per same figure and wiring schematic on Page 40iS/U-05.
Stripped the ends of the wires coming from the back of the LL-200 Landing Light and Crimped on male Molex pins to the end of each wire. Using a small piece of heat shrink, covered the green wire for the left and heat shrunk it.
Snapped the LL-200 Pins into the female Molex connector housing per the wiring schematic page 40iS/U-05. BLK Pin1, BLU Pin 2, YEL Pin 3, RED, Pin 4, GRN Heat Shrunk.
Connected the Male and Female Molex connector housings together and secured with a tie wrap per figure 1 40iS/U-07
Installed LL-200 Landing Light onto the W-1223B-L & -R using 2 AN3 bolts, lock washers, and flat washers supplied with the Aero LED LL-200. Pulled the light forward and parallel to the front edge of the W-1223B-L & R. Then tightened the AN3 bolts.
Secured the W-1223E lens backing brackets to the lens with a dab of RTV. Inserted the W-00014 lens into the opening and screwed it in place with 8 AN507C632R6 per figure 2 same page.
