Cleco'ed one of the W-1212 Hinge Assemblies to each of the W-1207B Rear Spar Doubler Plates orienting the parts as shown in Figure 1 page 14-03.
Riveted the inboard flange of the W-1212 hinge Assemblies to each of the W-1207B Rear Spar Doubler Plates using Rivets called out in Figure 2 same page and Identified the hinge assemblies and rear spar doubler plate as the Left and Right Doubler Assembly per call outs in Figure 1 same page.
Cleco'ed the left and right Doubler Assemblies to the inboard end of the W-1207A-L&-R Rear Spar Web as shown in Figure 1 same page.
Cleco'ed the W-1207C-L&-R Tip attach angles to the outboard end of the W-1207A-L& -R Rear Spar Web as showing in Figure 1 same page.
Riveted the left and right doubler assemblies to the W-1207A-L &-R Rear Spar Webs using the rivets indicated in Figure 2 same page. Left open the holes specifically called out in the same figure.
Riveted the W-1207C-L & -R Tip Attach Angle to the W-1207A-L & -R Rear Spar Web using the rivets called out in the same figure.
These subassemblies are now referred to as the Left and Right Rear Spar Assemblies and section 14 is completed.
