Brief Description: Flaperon Hinge Brackets and Hinge Assemblies
Cleco'ed one of the W-1216-R Flaperon Hinge Brackets to one of the W-1216-L Flaperon Hinge Brackets as shown in Figure 4 page14-02 and repeated for the remaining 3 left and right flaperon hinge brackets.
Riveted the W-1216-L&R Flaperon Hinge Brackets together using 8 each AN470AD4-4 Rivets using a random pattern to prevent warping. Each of these now referred to as W-1216 Hinge Bracket Assemblies and set aside for Secton 16.
Machine countersunk the W-1212B-L&R Flaperon Hinge Brackets per callouts in figure 5 same page.
Pressed one bearing COM 3-5 into each of the W-1212A Flaperon Hinge Plates as shown in figure 5 same page using a 7/16 inch, 3/8 inch drive socket and a 9/16 inch, 3/8 inch drive socket and a c-clamp.
Cleco'ed each of the W-1212A Flaperon Hinge Plates between one each of the W-1212B-L&-R Flaperon Hinges while pressing the area around the COM-3-5 Bearing together to insure that the bearing was seated into the recesses in the flaperon hinge bracket sides and not spreading the assemblies apart near the bearing.
Riveted the W-1212A Flaperon Hinge Plates and the W-1212B-L & -R Flaperon Hinges together using 3 each AN426AD4-6 and 7 each AN470AD4-7 rivets per Figure 5 same page.
Removed hatched area from W-1207C to create W-1207C-L and W-1207C-R.
