Brief Description: Empennage Kit Complete - Stabilator Fairing Final
Performed final sanding of the HS-1225 (left) Stabilator Tip Fairing.
Using painters tape to hole the stabilator tip fairings in position on the stabilator, match drilled #30 the holes in the stabilator and into the recessed flange of the stabilator tip fairings. Removed all debris after each drill and clecoed each hole after it was drilled
Removed stabilator tip fairings and cleared away all chips. Replace tip fairings and riveted all 32 holes using LP4-3 Rivets per figure 1 page 12A-03.
