Brief Description: Attached rudder cables to pedals
Attached rudder cables to pedals. Made 4 F-611 links, and discovered the supplied AN23-10 clevis bolts weren't long enough to follow assembly as in DWG 37. Instead, I omitted the castle nut and put the two links inside instead of outside the F-7121 rudder cable clevis. Had to add a slight double-bend to the link pairs for proper spacing. The cotter pin seems to hold everything ok but maybe I'll look at other builders' sites or call Vans to check this.
