Permanently installed the rudder pedals: fixed all cotter pins, riveted F-6118 Rudder Pedal Brace with pop rivets because the Firewall Recess was already installed, bolted and torqued all bolts to bearing blocks. Still need to drill F-6118 for brake line holes.
Discovered that I had installed the fuel vent lines AN833-4D elbow bulkhead fitting through the rudder cable hole. I removed those and ran the rudder cables properly, now I'll have to route that part of the vent lines correctly. Apparently during the QB build they riveted the hole that should be enlarged to accomdate the elbow fitting (DWG 23, Section G-G).
