Ralph Finch RV-9A Build
RV-9A
Plumbing
2-20-2011
Redid brake lines along spar
Finally fit the brake line segments along the spar. This one goes through, not in front of, the landing gear weldment. It runs through a lightening hole with a grommet which will prevent vibration wear. Ends will attach to two bulkhead fittings.
Brake line running thru left ldg weldment
Right side
Close up of line bending down to gear leg fitting
RV-9A Home
2214
162
Cowl
85
172
134
193
Firewall
Fluid Plumbing
560
Garage Setup
LdgGear/Wheels
90
Plumbing
324
