Brief Description: Started fuel pump install, substituted bulkhead co
Started on the boost fuel pump installation, using the boost Vans fuel pump housing and drawing as a starting point. Cut of the curved flanges on the new, thicker base plate, as my fuel pump (EFII Boost Pump Module) has its own frame which bolts on. Big question is where and how to install the filter. Could be in line, which would require extending the housing, or above the fuel pump, which would require a frame. Leaning towards the latter but will consult with Phil.
Decided to substitute bulkhead connectors instead of snap bushings for the brake lines between the firewall, and along the spar to the landing gear frame. Seems more apporpriate (safer and secure) since I have separated into 2 lines per side what the plans show as one line per side.
