Installed the Delta-Pop transponder and UAT antennas on fuselage underside. Bolt and coax holes were already drilled. Removed interior enamel around bolt holes for good electrical contact. Cleaned all contact areas, added Locktite gasket seal to antenna base, bolted on to fuselage using lockwashers on interior for better electrical contact.
