Brief Description: Started adjustment of canopy frame/skin
Started the fitting and adjustment of the forward canopy frame weldment & C-702 skin to fuselage. Ground off a bit from top forward right flange, and bent aft tube inward, to remove slight over-extension of skin on right side. Researched more on the canopy process on VAF...apparently the whole thing is a pain in the arse, trial-and-error process.
