Finished the canopy cabin frame: drilled and attached the F-732E angles, match-drilled and enlarge-drilled remaining holes, removed everything and deburred.
However I made a mistake and switched the size drill bit sizes in Note 1, Dwg 40, so when I went to tap the frame for the 8-32 screw it was loose. !@#*&^ To fix it I installed nutplates.
