Brief Description: Bolted angles to fuse, started attaching frame
Drilled and bolted the F-631C/D assemblies to the fuselage. Turned out to be a project because it was not easy to clamp and drill the assemblies to the F-705F channel...and when I trimmed the aft outside edge of the angles so the skin would lay smooth, the angles got pretty hot and dirty. I ended up removing the keeper rivets, stripping the zinc chromate and applying a fresh coat, then riveting together again.
Then started match-drilling and attaching the cabin frame assembly and channel brace F-732A.
