Brief Description: Continue right step installation
Match-drilled the holes in the rib and tube using the already-drilled holes in the plastic block as template. Cut and bent the lower trailing corner of the attaching flat plate, also the other step. But nicked one step while cutting...hmmm. I'll probably smooth and fill and see what happens in service. Last step, clean, prime and paint.
