Brief Description: Drilled elevator horns to attach elevs to HS
Drilled the elevator horns to attach the center bolt to the horizontal stabilizer. Though on final swing (up/down) measuring, the right elev leading edge rubs the HS spar a bit from about 25 deg to 30 deg, so I might have to deal with that on final attachment to fuse and elevator stop fitting. Maybe shoulda turned out the rod ends on that side a half turn, but they were measured carefully just like the left side.
With this, only the fiberglass tips are left to complete, including the tail light/strobe assy for the rudder.
