Ralph Finch RV-9A Build
RV-9A
Continue fitting landing gear supports
Match-drilled one screw hole on fuse side, and measured the other and drilled from outside the fuse (right side). But forgot to enlarge brake line hole to 5/8". Did enlarge left side. Fit both with more bolts to wing center section, etc.
RV-9A Home
2214
162
Cowl
85
172
134
193
Firewall
Fluid Plumbing
560
Garage Setup
LdgGear/Wheels
90
Plumbing
324
