Ralph Finch RV-9A Build
RV-9A
Continue landing gear support install
Continue cutting and fitting the landing gear supports OK, still need to test install the attaching bolts...
Notes:
The hole in the bottom fuse skin needs to be overlarge (beyond the paper template) to allow for the weldment to fit.
Watch for other obstructions, for instance, Image 2 shows trimming a fuse brace end to allow the landing gear piece to fit.
Looking at landing gear leg fit in bottom skin
Had to trim a fuse brace so landing gear would fit
Both landing gear braces installed
RV-9A Home
2214
162
Cowl
85
172
134
193
Firewall
Fluid Plumbing
560
Garage Setup
LdgGear/Wheels
90
Plumbing
324
