Brief Description: flaps, throttle, front wheel mount repair
cut more off pilot's stick to clear interference with left-side gauges start building pilot's position throttle quadrant with embedded flaperon actuator switch stop on this after first iteration: existing rocker switch is far too big to fit in palm of hand - research and order a couple smaller DPDT (on)-off-(on) switches to try - not sure what I need here yet
linear actuator ordered yesterday, due to arrive tomorrow build the actuator rig to go on the flaperon position crank assembly
more work on throttle quadrant - the linkage to rear throttle will be challenging, no matter what will want flaperon crank fairly well aft so it can be reached by rear-seat pilot
repair front wheel bearing problem - axle sleeve to hold bearing in place was missing pull and replace the front wheel mounting cross-bar and make a cleaner better cross-brace
