linear actuator arrived rig it up on the test stand and verify operation this thing is HEAVY for its size not sure I need the 150 pound version 35 pound version is actually a few dollars more expensive and weighs the same 5 pound version much lighter, much less expensive order it to test not sure if five pounds is going to be enough, but the factory flaperon adjustment rig is a window crank on a threaded bolt - it can't possibly be taking huge forces
