Brief Description: Building Jigs & Rolling leading edges
Today I built some jigs that will be used to hold the trim tab while working on it.
I also removed the right elevator from the angle iron and the trailing edge was perfect!
I cleaned out the holes with a #40 bit (rolled with my fingers) and then used the angle iron as a backriveting plate to set the rivets. It looks like a dream.
Finally I rolled the leading edges of the right elevator. It looks great.
