Today, I started finished shaping the Rudder Ribs. Nothing too special in the process.
I would suggest doing the longer ones first and working to the shorter ones. That way if you screw up cutting a long one, it's no big deal because you can use it at a shorter one instead. With a little luck, I didn't make any mistakes and they came out perfect.
They've been deburred and are waiting for assembly.
