I worked on making a better bracket for the main electrical loom carry through on the firewall. I cut a one and three quarter inch hole in a peice of 1.63 mm aluminium plate. I used a jubilee clamp to guide the cut through the aluminium tube. I will get the tube welded to the backing plate, which will be much better than the flat bracket.
