After talking to BDH a couple of days ago I decided to install the wheels and brake discs correctly. This will allow me finish the brake line installation and bleed the brake system here at home. My aircraft is an early edition and the brake calipers can not be installed with the wheel spat supports bracket installed. This will make changing the the brake pads in the future a much bigger job than on later edition aircraft.
