KSC and I spent some time today at the hanger preparing the wings for installation. We removed the wing root supports and riveted the five 4.8X15mm rivets on the rear spar plates on each wing. We installed the " Aileron Long Wing Push Rods " in each wing. I have not attached them to their " Aileron Bellcrank Bracket " yet, which allows them not to protrude too far out at the wing root, which will make attaching the wing a little easier. The " Flap Connecting Bushes " are taped on the flap torque tubes. We also bolted the horizontal stab. into position and torqued the bolts, just need to witness mark them later.
