I made a mistake when I painted the windscreen border. I only applied one coat of satin black paint, which I thought would be enough, which it is if you are looking from the outside. The following day when I looked at the border from inside the aircraft I noticed that I could see light though the painted border. The main reason I painted the border was to protect the SikaFlex from UV rays. So, with the help from KSC, I have " FineLined " and masked the windscreen again. I applied another three coats of satin black paint and you definitely can not see light through the border now. I will start on the rear windows tomorrow with help from KSC.
