Back home for two days, off to JNB this week. I installed the ELT switch on the inside left hand side center console panel. I had no room on the instrument panel, so I had to find another spot. Daniel from the factory, suggested the inside panel where the factory have installed a number of ELT switched in the past. The ELT came with screws and nuts for mounting, I decided to use rivnuts that will make it much easier for installation and removal.
