Des gave me a hand to do the final engine mounting which is greatly appreciated. We removed the engine to install the rubber engine mount correctly, I had them in incorrectly. Anyone mounting their engine should have a look at the TSI firewall forward build manual, re: rubber engine mount orientation. ( no mention in Sling 2 or 4 build manual ) I used S/S locknuts on the mounting bolts because of the heat in the engine bay and all four bolts torqued to 38 Nm. The engine hoist made the job much easier, being able to position the engine very precisely to attach to the engine mount.
