Peters Web Site
Date:  9-17-2020
Brief Description:  Brakes.
Installed the brake lines from the pedals to the park brake valve.
Took me awhile to figure out the best way to install the brake lines.
The right pedal on the left-hand side was the problem.
The brake line has to go on the floor to pass under the internal side panel and there is not much room for it to angle down to the floor.
After looking at photos I have from the factory I realised that the brake line needs to have a loop which allows it room to reach the floor.
I will install some continuous grommet where the brake lines pass over the toe brake pedal base.
Toe brakes.
Toe brakes.
Brake lines installed.
Toe brakes.
Toe brakes.
