Peters Web Site
Date:  7-4-2023
Number of Hours:  4.00
Brief Description:  Airbox Temperature Sensor.
I had ordered some dual core AWG 20 shielded wire which arrived today.
The temperature sensor for the airbox is arriving tomorrow.
I worked on the harnesses for connecting the temperature sensor to the GEA24.
The harness requires a 1 k ohm resistor to be connected from the Temp Hi wire to a Temp +5V wire, therefore three pins to the GEA24 J244 D-Sub connector.
( positions 14,15,16 ).
Dual core wire with resistor installed.
Connecting to the GEA24.
Airbox temperature harness.
