I started working on the drainage pipelines to the airbox and drip tray. The factory use clear plastic 6mm tubing which obviously works, however I decided to use 6mm silicone hose. The drainage hoses are close to heat sources so the silicone hoses will be more heat resistant. I purchased some constant tension spring clamps to connect the hose to drip tray and airbox. I was going to use the clamps on the " T " connections, but they would be a scratch hazard, so I safety wired the connections.
