I shortened the two outer casings of the choke cables. I installed some heat shrink on the end of the cable so it would sit a little more secure in the ferrell. I safety wired the cable outer casing to the " bent tube assembly". I'm not sure if my safety wiring is satisfactory, so I will consult with my technical advisor, BDH, before I apply heat shrink.
