Peters Web Site
Date:  10-10-2021
Number of Hours:  12.00
Brief Description:  Avionics.
Been busy the past couple of days with a number of issues.
The first issue is one of the GSA28's ( autopilot servo ) has failed.
The servo displays a power supply and hardware fault on the configuration page.
I swapped the pitch and rolls servo's and the same fault went with the servo.
I have contacted the supplier and we are evaluating available options.
Garmin should replace the servo as it has not left the build shed yet.
When I was talking to Garmin in Sydney, I was offered a 28 day free trial of a complete Australian Garmin data package.
I have downloaded the package and installed it into the G3X system.
I had not tightened the nose wheel steering boots on the firewall, a big mistake, so I went under the dash again to tighten them, a very dfficult maneuver.
Still securing bits and pieces under the instrument panel, nearly complete.
Ground bus.
Ground bus.
Nose wheel steering boots.
Instrument panel.
Instrument panel.
