Peters Web Site
Date:  9-28-2021
Number of Hours:  8.00
Brief Description:  Wiring.
The past couple of days I have been working on securing the wiring behind the instrument panel.
I have a few aches and pains and bruises, I'm definitely not designed to be under an instrument panel.
I have some larger cable tie saddles which have a large 4.8mm hole and I wanted to secure them with a 3.2mm rivet.
I used the drill press to file down some wide 3.2mm washers to allow me to use the larger saddles on existing 3.2mm rivet holes. ( washers,11.8mm wide down to 10.8mm wide )
Photo 2. Left side washer original, Right side washer filed down and fits in saddle.
VPX
VPX
Original and modified.
3.2mm rivet in saddle.
