Peters Web Site
Date:  8-17-2021
Number of Hours:  4.00
Brief Description:  Oil System Hoses.
Worked on the oil system hoses and connections.
Connected the turbo overflow hose to the banjo and re-torqued the connection.
I had to replace the hose from the thermostat to the oil pump because I cut the hose too short, well, only one end was too short. ( that took quite some time ).
Once hose was replaced I connected it to the oil pump.
I also made a new bracket for the turbo oil overflow oil hose.
Turbo oil overflow hose.
Thermostat to oil pump hose.
Oil pump and hoses.
Oil pump and hoses.
