I connected the expansion tank to the overflow bottle. The factory run the hose along the inside the right carburetor then above the starter motor to the rear of the engine, so I did the same. The hose fits on the expansion tank is very tightly, which would not allow me to use a screw clamp or a Oetiker clip, so I tie wired the hose to the expansion tank which should work OK.
