Peters Web Site
Date:  6-11-2021
Number of Hours:  4.00
Brief Description:  TCU Wiring.
The Rotax engine comes with the two TCU servo plugs attached and two very long lengths of wire from the TCU.( wires 2 and 14 )
I have the wiring from the TCU servo cutout switch ( DPST ) on the panel, through to the engine bay.
So I had to connect the TCU servo cutout switch wiring into the Rotax TCU servo loom.
I have removed about a 1.5 metres of surplus wire.
I tested the continuity through the TCU servo cutout switch from the TCU plug to the TCU servo and all is OK.
Surplus wiring from TCU.
Wiring to TCU servo finished.
Much better.
Much better.
