Peters Web Site
Date:  3-27-2021
Number of Hours:  1.00
Brief Description:  G3X Display.
I spent some time configuring the G3X to display an alert when the
IBBS ( Intergated Back-up Battery System ) is being used.
With help from BDH, I found it very straight forward to configure the G3X alert.
Pilots need to know when their aircraft avionics are being powered by the IBBS, as time becomes a crucial factor when airborne.
For other builders, who maybe interested, this is how I configured the G3X display.
1. Go to configuration mode display on G3X
2. Tap Engine & Airframe.
3. GEA24 input, GEA24 Discrete, Settings will be displayed across top line.
4. Tap GEA24 Discrete.
4. Tap Discrete 1 ( that's where mine worked ).
5. Tap Input Type, select Active Low.
6. Tap Alert Color, select Yellow.
7. Tap Alert Label.Type whatever you like ( Stby Bat, Stby inuse, IBBS inuse, Bugger, Land soon, ????? )
8. Save and reboot configuation page.
Alert Label should be displayed on G3X when the standby battery is being used.
Hope this works for other builders, it maybe useful before starting and when airborne.
Configuration Mode.
Configuration Mode.
GEA24 Inputs.
GEA24 Inputs.
GEA24 Discretes
GEA24 Discretes
