More Baffle pictures. I also had to reroute and relocate the governor cable. The inlet around the A/C was pretty straight forward. I used the original Van's piece, cut it and bent it upward to clear the A/C compressor. I then added a filler piece and a bracket to bolt it to the compressor bracket. I also bent the leading edge of the baffle 90 degrees to stiffen it.
