After deciding the battery is going to go on the firewall to keep the weight and balance right I remounted the ELT where the battery was and added a mount for the oxygen bottle. The oxygen lines run up the side then over to the center console where the interfaces are mounted. The control panel will be mounted next to the G900 on the pilots side.
