Installed the instrument panel. Had to finish installing the insulation, seal the firewall, tighten up the A/C system before I could put it in. I have to say I love the look of the Aerosport panel but the installation was difficult. You have to remove the inserts where the screens are mounted then unbolt the carbon fiber cover to get to the frame that bolts to the plane. This leaves you trying to handle 3 pieces during the install all while trying to put in screws at an angle. I taped the painted portions of the panel to protect them from being scratched. Still scratched it areas.
