Brief Description: Continued work on Baggage Floor
The baggage floor was final fitted after the side L anges were cut to allow for the reinstallation of the rear spar support bulkheads. The upper cross support was installed between the bulkhead and then the floor was re-installed.
The upper seat support was joined to the fuselage via an L angle on both sides.
L angle cut to allow installation of side rear spar supports. Also upper cross support in place
