Brief Description: Re-assembled front of fuse and worked on spar box
Re-assembled the lower front fuse today after deburring and priming. I installed permanently the rudder pedal mounting points. I also riveted the brake pedals onto the newly powder coated rudder pedals..
I continued work on the spar box alignment jig. I cut out two sets of 3 alignment templates as spelled out in the plans. I made 2 of each so that I could be sure both sides are aligned correctly.
Fuse front reassembled after priming
Spar box jig components
Rudder pedals back from powder coating and riveted
