Paul's Zenith 601-XL
Date:  3-4-2008
Number of Hours:  4.50
Brief Description:  Spar box and debur
Located and installed the wing spar box onto the front lower fuse skin. Then I disassembled, deburred and primed the front lower skin parts.
The spar stub assembly was started but it is slow going since I want to get it right. I brought home the plans so I can cut the plywood angle gauges for installing the forward bulkheads and firewall.
Spar box drilled in place
