Brief Description: Clean-up work and joining of the front and rear fu
I did a lot of little things that needed to be done before moving on. I installed new rudder fairings and fairleads since I was not happy with the mounting angle of the first set. I made the mistake the first time, so this time they are much more in line with the airflow
I aligned the fuse components on a centre line I snapped down the table and joined the front and rear fuselage sections.
The spar box was unpacked, and all the centerlines marked and the stub spar sections clamped in place.
Fairings and fairleads, part ][! I bought some new ones to make them fit better. N-66 not mounted ye
Front and rear fuse bottoms drilled and clecoed together
