The replacement skin arrived a few weeks ago (before spring break traveling). If you remember, the original skin was damaged in the shipping of the kit. Since I worked on the plane most of the day, I could only sneak out into the garage for a little bit to get the rudder skinning started. I have the rear skin drilled to the skeleton.
Tomorrow, I will attach the nose skin.
Skin drilled. Note the 3/4" block on the trailing edge
