I had a couple of hours today so I set out to get the leading edge of the right elevator bent and riveted. This proved to be a little more difficult that the rudder leading edge. ( I think it was because the smaller ares to work in with a narrower spar) Anyway after some manipulation I was able to get the surfaces to meet pretty well and then I match drilled the holes to size and after deburring the holes, I recleoed them and then set the blind rivets along the leading edge. I was content with the outcome.
