I had a few minutes today and I fastened the rod end bearings to the right elevator and set them within the 13/16 of an inch to 7/8 of an inch per plans. I will modify my #14 metric wrench later to really get the lock nut set well enough. That pretty much wraps up the right elevator until I get the left one done and check the balance and attacht the fiberglass tip. Late Note: I went to my buddy Danny's house and bent my #14 wrench and went back home and tightened the locking nut on the rod end bearing. I hung the right elevator on the wall with my other collections and set out the parts for the left elevator and trim tab.
